Battery life is draining at 3times the speed
Discussion in 'iPad Hacking' started by seanbediako, Jun 4, 2011.
  1. seanbediako
    seanbediako
    Jun 3, 2011
    Battery life is draining at 3times the speed as normal since I jail broke my ipad 1 wifi (4.2.1) using green poison
    Please help anyone?
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    You need to tell us what Cydia applications you have installed. The jailbreak itself does NOTHING to the battery consumption. It is ALWAYS a symptom of something you have installed which is usually not compatible with the iPad. You need to list out what you have installed and we will see if we can help. OK?
  3. Oops
    Oops
    May 18, 2011
    148
    Not sure if this will help...
    A month or 2 back I JB'ed my mates iPhone 4 and he experienced the same issue... The battery was draining super fast.
    I took the phone home with me and started sifting through endless amount of complaints about this and finally came to a solution... It appears that after the JB, if you have an exchange mail account added on with the options to sync email, contacts and calendar..... The contacts option is the issue. All I had to do was deactivate the contacts sync and tadaa... Battery stopped draining like crazy.
    Not sure if it may the same issue on the iPad... Hope it helps.
  4. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    Great post. I learned something today!
  5. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    Jailbreak does nothing but open up root access and install Cydia. :)
  6. seanbediako
    seanbediako
    Jun 3, 2011
    Here is a list of things it say under the installed tab at bottom:
    A
    An Arsenal boot logo
    Animate
    B
    BigBoss icon set
    C
    Cydia installer
    Cydia Translations
    E
    Enhanced Ctorrent
    Essential
    I
    Ifile
    M
    Mobile substrate
    S
    Safari download plug-in
    Sauriks source
    Sringboard access
    I also downloaded snes4iphone app before I found out it doesn't work for the iPad so I removed it?
    Oops pls bear with my lack of know how but can you or someone pls tell me how to turn off the contact syn setting?
    Cheers guys
  7. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Safari Download Plugin is built for iOS 2.0 AFAIK! Try getting rid of that...
  8. seanbediako
    seanbediako
    Jun 3, 2011
    Ok I have removed it, hopefully this will slow things down. Also the whole iPad has just switched off on me and I can only see the silver apple symbol so I have had to use the reset method a few times :-s
    I'll keep u posted
    Cheer mate
  9. Oops
    Oops
    May 18, 2011
    148
    Click settings,
    click mail / contact / calendars
    Click on your email account
    You will see
    Email
    Contact
    Calendar
    If contact is switched on, click it to toggle off
    Hope it helps.
  10. Don9307
    Don9307
    Jun 4, 2011
    32
    I have a jail broken iPhone 4 with an Exchange account with sync enabled and I don't have this problem at all.
    Sent from my iPad 2 using iPF
how to stop ipad battery from draining. cydia apps
mobile substrate fast drain battery
mobilesubstrate battery drain
mobilesubstrate battery fix
ultimate battery draining application on ipad
what cydia apps drain battery
