Does Jailbreaking Improve Battery Life?
Discussion in 'iPad Hacking' started by dragon499, Jan 21, 2012.
  1. dragon499
    dragon499
    Aug 12, 2010
    284
    11
    My battery was 100% before I jailbroke. I have been playing around for 2 hours, and on 3G for at least 15 minutes. 3G drains the battery more than wifi. I am only down to 98% now. This is an unusually slow drain. My sensors app agrees with the built in battery indicator.
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Jailbreaking makes absolutely no difference to your battery. It's the apps and tweaks you install after the jailbreak which have the potential to drain your battery. There is no magic trick to miraculously increase your battery life.
    If you restored your device before you jailbroke, you may see some improvement if you had some badly behaving apps and processes in your previous setup. This is no unheard of, but a restore would have given the same results, regardless of the jailbreak.
  3. dragon499
    dragon499
    Aug 12, 2010
    284
    11
    I didn't restore. Could the restart have freed up resources used by apps badly behaving?
does jailbreak drain battery
does jailbreak drain battery life
does jailbreak kill battery
does jailbreak kill battery life
does jailbreaking drain battery
does jailbreaking improve battery life
does jailbreaking increase battery life
does jailbreaking kill battery
does jailbreaking kill battery life
does jailbreaking use up battery
