Help....can't print coupons. Says I need adobe flash player?
Status
Not open for further replies.
ssanctuary
I need help to figure out how to get my iPad to print coupons, none of the sites are accepted by my iPad and says I don't have the right software??
The iPad does not support flash. There are a few apps but some find them sluggish and unpredictable. ISwifter, Puffin, to name a few.
There are also over a hundred threads re flash if you use our search button. So we will close this one.
Good luck!
Closed.
Status
