Messages will not send!
WhydidIbuyit
Canada
Hello!
I am having difficulty with the iMessaging program. Sometimes I am able to SEND a message, complete with photos and movie clips. Most of the time nothing happens and I'm not sure what I'm doing/not doing that results in my message just sitting there. The word SEND is highlighted ... but it does not send. I'm sure your answer will simply mortify me with its simplicity ... but I'm prepared to humble myself.
It's been quite awhile since I asked this question and I'm wondering if I've posted in the wrong area. I'm still not able to SEND my iMessages.
WhydidIbuyit
WhydidIbuyit
Canada
Okay, I give. Did I just not put my question in the right place?
Milton-Freewater, OR
Most likely no one has a good answer for you, and like me, was waiting to see if anyone else had an idea of what is going on. The only thing I can think of is that you don't have an internet connection when it's not sending.
Other than that, all I can recommend is the usual fixes, if you have not already tried them.
The usual fixes:
Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
KevinJS
Edmonton AB Canada
First time I've seen this question, so sorry to have missed it. All I can think of from the info given, is that you may be typing your message into the space intended for the title. That would prevent it being sent, because the body would be empty, but I'm pretty sure that in this case the Send button would be greyed out.
So, a few questions. Are you jailbroken? Are you finding difficulty in sending to the same people, or is the problem purely random? Are you sure your contacts have iDevices?
The more info you can supply, the easier it will be for us to track down the problem.
skimonkey
Michigan. USA
...and we will now move this to the Help Section in hopes to bring on more attention to this.
Thanks,
Ski ~ iPadforums Moderator | iPhoneForums Moderator
WhydidIbuyit
WhydidIbuyit
Canada
Well, after reading everything I could find about the subject ... and probably missing the one article that would be the permanent "fix" ... I have decided that I just have to accept that the problem is sporadic. Last night I was able to message back and forth. Today the SEND button ignores me.
I shut down all apps sitting in the tray, powered off the iPad completely after doing the usual clearing of cookies etc., switched my search from Google to Bing first and powered back on. SEND is working again.
WhydidIbuyit
WhydidIbuyit
Canada
OMG!!! I am absolutely mortified! My apologies to one and all! I have been looking below my post for possible responses, completely missing the list ABOVE my post!
Really, someone should just take this thing away from me before I do any more damage!!! :rolleyes:
No problem. We all make that mistake now and then, or at least I do. :)
It's probably the restart that is fixing the problem. You should probably restart the iPad every week or so. If you're having to do it every day, something is wrong, possibly a bad app that gobbling and not releasing RAM.
WhydidIbuyit
WhydidIbuyit
Canada
I'm sitting here laughing and blushing. I'm hopeless! Yes, I had actually done everything you suggested already. The only thing I hadn't considered was doing the reset all settings. That prospect made me nervous. I'll play with it a bit longer before I take that step. It is apparently working again now ... for the moment at least.
My next project will obviously be to change my settings from "threaded view" to "default" (which I should have left alone to begin with!).
Thanks so much for your usual thoughtful reply.
WhydidIbuyit
WhydidIbuyit
Canada
Actually I haven't used the re-start button since I bought the thing. I have one of those flip top covers that puts it to sleep. From now on I will make a point of doing a weekly re-start.
Ta
Ta
It's easy to overlook that the screen going black is not actually turning the iPad off, and that this easy to use device is still a computer that needs an occasional clean start.
Hope this helps.
