iPad- Redsn0w Jailbreak charging problem
Discussion in 'iPad Hacking' started by Takeover, Mar 4, 2011.
  1. Takeover
    Takeover
    Mar 4, 2011
    i, I jailbroke my iPad with redsn0w and everything worked fine. Until about 2 weeks ago when I didnt charge it and now its stuck at the apple logo. I tried the option "just boot tethered now" on the redsn0w program but heres what happens:
    - my ipad just turns off and shows the low battery image
    - after completing the 10 seconds, 15 seconds, etc. of pressing the home and power buttons, redsn0w just says that it failed to recognize any devices, and to consult google or youtube on how to enter pwned DFU mode.
    For the most part ive waited days and just left it charging and then i try it but it will go back to the low battery, I dont know how thats possible.
    Has anyone had similar problems? Possible solutions?
  2. vista com
    vista com
    May 13, 2011
    not charging
    My friend!
    check i your I Pad charging bass.i m shure its has something in charge socket .
  3. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    I moved your thread to the Hacking Section.;)
  4. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    You will have to charge the iPad from a WALL charger for a while so you get enough juice in the battery to complete the boot process. You won't get it recharged from a USB port!
    Once you have charged it using a wall charger for a while, THEN you should use redsn0w to "just boot tethered right now".
    Then, I suggest you get yourself upgraded onto an untethered jailbreak version!
    Hope that helps.
failed iphone jailbreak now my battery wont charge
how to jailbreak ipad charger problem
ipad slow to charge after jailbreak
ipad will not boot just shows battery with red
ipad wont iphone will not charge after jailbreak
iphone wont charge says its charging tethered
jailbroken ipad charge problem
my iphone battery not charging after jailbreak
my iphone battery went dead while i was jailbreaking and now it won't charge enough to reboot
problems with tethered jailbreak with charging
