Wireless not connecting
Pharlap
After upgrading to ver 4.3 wireless is able to be seen but cannot connect any body have a clue why this is
One of the Forum moderators wrote this recently
"This has resolved many issues and worth a try.
__________________
Cheers
Col
col.bris, Brisbane Australia
Forum Rules. Please Read."
Thanks try also switching off power to modem and ipad then. Restate modem router then connect. I'd this fails you may Ned to change security settings in the router pending brand. Using tour pc to connect
