Strange safari problem
Discussion in 'iPad Help' started by Tobiasrx, Jul 28, 2010.
  1. Tobiasrx
    Tobiasrx
    Jul 13, 2010
    I usually use my ipad in landscape view and after awhile surfing the top left corner isnt touchable. The back button works though. Its only in safari the menu works fine. I have to restart my ipad for it to go away.
    Also if i touch in an area wich works and then move my finger to the nit working area it works. But when i lift my finger and directly place it in the non working area it doesnt work again.
    Anyone else had this problem? This has happened 3 times in a week now.
  2. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    is your ipad jailbroken?
  3. Tobiasrx
    Tobiasrx
    Jul 13, 2010
    No it is not.
    I made a video of the issue
    Its on youtube. Search for strange ipad problem.
    Cant link it yet here.
  4. mslammers
    mslammers
    Jun 14, 2010
    174
    Tobias,
    It looks like a screen sensitivity situation. I notice often that this occurs with some of the larger programs. What it looks like to me is that the processor is lagging behind a bit. It is really hard to separate the OS behavior from the App behavior sometimes. Unless it is driving you to drink or something, I would try to live with it. I do notice that when you get the page to move by tapping in the center and then slide your finger to the left, you can still move the page. I suspect it is a Safari characteristic.
  5. Tobiasrx
    Tobiasrx
    Jul 13, 2010
    Im not so sure its lagging cause im only having one page open in safari. It doesnt go away either until I restart my iPad. This has never happened on my iPhone.
  6. pik0
    pik0
    May 3, 2010
    193
    I am unable to recreate that failure mode. Tried many variations including what appears to be a tap-drag gesture that you did on the wikipedia logo. Still scrolls just fine for me. Same in landscape and portrait. I even brought up wikipedia to see if that was a factor. No dice.
    Get thee to an Apple store if possible or at least contact Apple for a replacement.
    Apple - Support - Contacting Apple Support and Customer Service - Phone Contacts
    Piko
  7. sairin8
    sairin8
    Oct 19, 2010
    Just had that same issue now... restarting worked for me, though I wouldn't mind not having the problem in the first place
  8. Hasty
    Hasty
    iPad Ninja
    Jun 2, 2010
    2,266
    22
    If you're not happy methinks best to get it checked as pik0 said.
    I prithee go to!
ipad safari pages going weird
iphone 5 iphone safari stuck in landscape
iphone 5 stuck in landscape in safari
iphone stuck in landscape mode safari
safari app stuckin landscape
safari isnt working on my ipad
safari stuck in landscape mode
safari stuck on portrait
