Caharo
When doing the test call with Skype I can here the operator's voice (incoming) but not mine (outgoing).
I cannot find any settings to address this!?
Tim SPRACKLEN said:Several members have had this problem and the 'cure' below seems to work (but also check you haven't got the Skype 'Mute' control activated!)
I tried the first solution but I can't find my app again???? Frustrating!
Frustrating!
I found something under purchased in the App Store. It's got a cloud next to it. If I click on it to download, does it use my 3G data or should I wait for hi fi connection? Thanks for your help.
