Problem sending photo
wfish
I used to be able to go into my photos and send to my email account. Now when I send them I get the email but no photo.
D
Deleted member 247820
Guest
Hi W Fish.
What happens when you email from Camera Roll?
Will that solve your problem?
W
wfish
I'm sending it from camera roll. This used to work.
D
Guest
Hi WF
Describe how far you get doing the procedure in camera roll.
scifan57
Regina,Canada
Do you get this pop up?
image-1375431866.jpgif you tap on mail, it should send the photo to your email, where you can add the address and any message. Your default email account has to be open, however, for it to work. If your account is closed at the moment, this won't work.
W
wfish
Are there any settings that can prevent a photo from being sent?
scifan57
Regina,Canada
Has any part of your Internet connection changed? If the bandwidth is too narrow, it could possibly affect the emailing of large attachments.
W
wfish
<img src="http://www.ipadforums.net/attachment.php?attachmentid=34241"/>if you tap on mail, it should send the photo to your email, where you can add the address and any message. Your default email account has to be open, however, for it to work. If your account is closed at the moment, this won't work.
Yes, I get that pop up and I select mail. I then select my email account. I can see the picture in the email. At the bottom it says sent from iPad. I then send the message. When I get on Internet and check my mail I see the message was sent. I get everything except the picture, I see the message sent from iPad. I've tried several different pictures and ones that were sent before but none of them work. I'm at a loss.
scifan57
Regina,Canada
Is there an attachment link in the email, which when opened up, reveals the photo?
W
wfish
Nope. No attachments. When I send it I see the photo in the body of the text.
readyfreddie
go. directly to your pictures, press and hold the picture, a box. should open with all the apps you can send picture to when you see the email press it. your email format will open and the key pad should come up. add all of the normal email stuff and they hit send. check the sent mail and see if your picture was attached. if so you have it. Freddie
