Ipad detection problem with Vista and iTunes
Discussion in 'iPad Help' started by raghu11188, May 19, 2011.
  1. raghu11188
    raghu11188
    May 19, 2011
    11
    I've been using the iPad since almost 6 months and have never experienced any connection problems until recently.
    The iPad wouldn't charge when connected to PC, but it would at least connect and sync.
    Recently, since 3 days I started facing this problem. The computer doesn't show up anything when I connect my iPad, nor does the iPad even blink when the cable is plugged in. It doesn't even show the "Not Charging" sign. iTunes used to start up automatically but now it doesn't. Even Vista doesn't seem to recognize it anywhere because I don't find the iPad listed in the USB devices
    Strangely I don't face the same problem with my iPhone 3G.
    I've updated it to the latest iOS 4.3 and I'm also using the latest iTunes 10.2.2.14 and the latest USB drivers.
    I'm using Windows Vista on Dell Desktop with Intel core 2 duo.
    Before you suggest, I want to let you know I've tried out the following
    1) restarted iPad
    2) restarted PC
    3) erased and reinstalled all apple software (iTunes, QuickTime, bonjour etc)
    4) updated USB drivers and also ran a virus check.
    5) stopped and restarted the Apple Device service.
    I haven't changed the cable and checked and I don't think there would be a problem with the cable because the iPad and iPhone charge perfectly when connected through that cable.
    as I've already mentioned, I don't have the problem with my iPhone.
    Is anybody here faced/facing the same problem?
    I'd be really thankful if you have a solution.
    PS: I've installed ASIO4all drivers and Soundmax audio drivers. Could they be causing this problem?
    Regards,
    Raghu
  2. ipfuser55
    ipfuser55
    Apr 23, 2011
    667
    It sounds as if you have worked your way through most things. I would not dismiss the possiblity of a small bent or broken pin or pins on the cable. It may still charge, but not connect. I would get another one and try it.... Borrow if you can :)
  3. Rudinater
    Rudinater
    Mar 23, 2011
    197
    Ok you have pretty much ruled out the computer . . .. .
    Now take your Ipad to a apple store or a best buy and see if one of their computer will detect your Ipad. Try that with your cable and try it with one of their cables.
  4. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    I didn't see you say you'd tried a different USB port. This often solves it. Also, you are not using a hub, right? Try swapping the cable into a different port.
  5. ipfuser55
    ipfuser55
    Apr 23, 2011
    667
    Since we have heard nothing from this chap for a while, maybe he is getting a new iPad Or PC?
  6. adammsu
    adammsu
    Mar 25, 2011
    24
    i have essentially the same setup, and it happens to me sometimes too. i just unplug and replug. seems to work better if itunes is NOT running when i plug it, i let the connection open the prog...
  7. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    It's only been one day.;)
  8. Wolfpuppies3
    Wolfpuppies3
    Aug 9, 2010
    732
    10
    Once in a blue moon that happens to me and I resolve it by
    removing my cable from a USB hub and connect it directly to the computer's USB port. One failure necessitated replacing the Apple cable, not a problem as I have 4 or 5 around the house.
  9. raghu11188
    raghu11188
    May 19, 2011
    11
    Ok.. I haven't disappeared. :)
    I was just waiting to borrow my friend's cable. I have only one.
    And yes, I am not connecting it to any hub. I connect it directly to the USB port of the computer. Tried every port.
    Will check with a different cable tomorrow and get back to you guys. Thank you so much. :)
  10. TrackRat
    TrackRat
    May 5, 2011
    I have a tough time getting my windows xp to recognize my iPad. When I first bought the iPad I actually had to plug it into m wife's Mac book just to jump start it. Then I plugged it into my IBM laptop without an issue. Since then... No joy.
apple ipad driver for windows vista
driver for ipad windows vista
ipad 2 driver windows vista
ipad detection problems
ipad driver windows vista
problems connecting ipad to windows vista
vista doesn't see ipad
vista wont recognise ipad 3
vista+doesn't+recognize+ipad mini
