Ipad 4 wifi problem
Discussion in 'International iPad Users' started by deepansh, Nov 19, 2013.
  1. deepansh
    deepansh
    Sep 26, 2013
    Guys,
    I am having a wifi problem with my ipad 4 . I mean when ever I switch it off it does not auto connect to my wifi...!
    Any ides why so??
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,223
    Huh. I should automatically find that WiFi signal when you turn it back on. So, a few suggestions:
    Have you tried to reboot the WiFi router? Sometimes it needs a reset.
    Or, have you tried to restart or reset the iPad? Oftentimes, one of those two helps the iPad start acting as it should. To do (apologies if you know):
    If that doesn't help, try this last step...
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (on some iOS versions, the "slide to power off" button will appear; just ignore it). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    Hopefully, one of those ideas will help. If not, come on back and we'll try something else. Good luck.
    P.S. I deleted your other thread you started today on this same topic. Making more than one post not only fragments the conversation and makes it hard to follow - it's against the forum rules. Please keep any follow-ups, discussion or updates on this topic to this thread; do not start another. Thanks for your understanding
  3. deepansh
    deepansh
    Sep 26, 2013
    Dude thnks for ur advice !
    I tried restarting my ipad but didn't try rebooting my wifi router...will try n let u know ........
  4. deepansh
    deepansh
    Sep 26, 2013
    Hey i tried ur suggestions but without any success....!!
    Can u plz,suggest me ne thing else..
  5. BamaFan
    BamaFan
    Aug 18, 2013
    9
    I am having this problem too. I have tried all of the suggestions that I've read about, but no joy.
    Why is Apple being unresponsive on this issue? I know, because they can. Is there a real software fix in the pipeline?
ipad 4 wifi issues
ipad 4 wifi problem
ipad 5 wifi problem
