f4780y said:Yes, once you have bought it, you own it. You can remove and re-install it as many times as you like. Don't be put off if it looks like iTunes wants to charge you again. It will not. You will always see a message saying you already own the program and won't be charged again once you try and install it.
It takes a little getting used to, but have faith.
Hope that helps.
