Smart case or smart cover
Jack1231
Hi. At the moment I've got a smart case, light blue. But I want an easy case for home. And I would use my smart case for travelling. Do you think this is a good idea. I have had a Smart Cover before but sold it for a smart case. I still like the smart case but I like to take it off sometimes and it's a bit fidilly. Thanks.
Sure, if that's what you like. If you want to protect the back, consider getting a skin....like those from iCarbons.com or from bodyguardz.com. These are super thin and light, and stick to the back. They will protect from scratches and light dings...not from a drop. Then use your smart over to protect the screen when not in use. You should be able to use your smart case too because the skins take very little room and add essentially no bulk.
I was just thinking about using my Smart Cover at home (where it wouldn't get scratched) and use my smart case when I'm out.
Why would it not get scratched at home? For me, that's the most likely place to get a scratch! :)
Well at least when I'm out no one would see the scratches if I have my smart case on. And my iPad never get scratched really at home. Gets scratched more if I'm in a cafe or just out.
