NEED HELP; restoring my ipad 2 for jailbreak
Hi, Im having problems with my ipad. I need to download 4.3.3 so i can jailbreak from jailbreakme.com, My current version is 4.3.2, I downloaded the 4.3.3 (ipsw) in order to update my ipad 2,
***I Put my ipad in DFU mode and Pressed alt+restore to click the ipsw file***
A error message comes up shorty saying " The ipad could not be restored. THis device isn't eligible for the requested build.
How can i bypass this error message? And resotre my ipad 2 to 4.3.3
Thanks;)
100% correct. You haven't saved your blobs so you have to upgrade to 4.3.5. Sorry.
I think you can jailbreak 4.2.2 though.
Go to jailbreakme.com and see what it says.
If you have an iPad with iOS 4.3.2, you cannot jailbreak it. JailbreakMe only works for the iPad2 running 4.3.3.
And, as the others have said, if you don't have SHSH blobs saved for version 4.3.3, you cannot load that version onto your iPad (and thus be able to jail break it).
Sorry, but you've missed the opportunity.
You need to have connected to Cydia when apple was still signing the 4.3.3 firmware... If you haven't then a restore to 4.3.3 won't happen... Only way to find out if you are not currently jail broken is to try the restore with the modified hosts and see what happens... I've tried it and it didn't do anything... Just returns an error. Make sure you read tutorials on entering DFU and you should be fine. However if you are not sure, then you most likely don't have the saved blob. But it doesn't hurt to try, just be sure to do a backup first.
If any of my information is incorrect, someone please feel free to correct me.
Averros
ohh, so i must have jailbroken it before to upgrade to 4.3.3? Also how can i save the SHSH files when i jailbreak it?
No, jailbroken or not, you will still get an error if you try to go to 4.3.3. And you don't have to be jailbroken to save shsh.
To save shsh though, download tinyumbrella (google it) and plug in your iPad and hit save shsh. It will save shsh for 4.3.5 and iOS beta 5 of you are a developer.
I understand, Is there any other alternitve methood i can jailbreak the pad 2, is there any way to jailbreak firmware 4.3.2 or 4.3.5?
Hi, I almost went into the same situation as well, was using a JB 4.3.3 and had problem with it struggle for 2 days finally got it reinstalled.
You can't go into your 4.3.2 anymore ? Or if you are able so, just download TinyUmbrella and run the program. Try to save your shsh blob, have the "chk with cydia" option ticked to see whether you can save a set of 4.3.3 blob from cydia, of your device specific id.
If your is a wifi version, as I understood it, you can upgrade to 4.3.5 and yet save the blob for 4.3.4. As there is no change in baseband, you can use TU to run the TSS service later and downgrade to the 4.3.3 firmware that you downloaded. I may be wrong though
If you can, then we can talk about next step, if not, sorry and enjoy the stock 4.3.5 :(
You are wrong I'm afraid. Please read our stickies for the facts on blobs. The OP has no way to JB or save blobs for anything but 4.3.5.
