I understand how it works but when I re-sign in to the forums and then go back later I have to sign in again for the 2nd time only then will it remember my sign in info. This happens on all the forums I go to. BTW it doesn't do this on my iPhone.
If you are signing in on the website using safari, make sure you check the "remember me" box. That way, you are always signed in.
Yes I checked the remember me box.
Go to settings > Safari> and make sure your private browsing is turned "OFF"--that way you ipad can accept this site and its cookies.
Try that.
Yup it's turned off. This is very strange after the 2nd sign in it remembers my user name and password.
So it is working now?
Have you tried to close out all your apps and do a restart? Than retry.
If that doesn't work try do to a reset by holding the power button and home button together until the apple logo comes on to shut it off. Than retry.
I think that worked I shut off my iPad turned it back on and that seemed to work Thanks for your help.
