Wireless connection issue with wifi sync and when using Air Video on my iPad...
Discussion in 'iPad Help' started by papalazarou, Dec 18, 2011.
  1. papalazarou
    This is a bit of a long winded issue, basically I have a Sky broadband router which is next to useless in its wireless connection. I have a 2nd wireless access point which helps me get wireless connection BUT when I use it to connect both wifi sync and Air Video no longer work. Wifi sync won't allow connection between my iMac and iPad, it's as if they can't see each other. I assume there are some settings I need to adjust on the access point, maybe opening up certain ports on the router to allow the access point to work properly. If anyone has any suggestions I would really appreciate it, I am running version 10.6.8 of OSX and I have version 5.0.1 on my iPad and the latest version of iTunes so everything is up to date.
    Many thanks,
air video wont connect
airvideo won't connect
how to connect air video by wifi
ipad won't connect to air video
