WiFi issue with I-Pad2
Link1369NY490
MA
Good Evening folks! Hey have any of you had an issue with WiFi signal, or reception? Let me give you two examples. I take the train into Boston every day, and the week i got my new shiny I-Pad2 i was showing it to my friend and well his Ipad found the trains WiFi with no problem and my wonderful new I-Pad 2 could not? and then mutiple time since then the connection is not that good. The the second example is when my youngest child in nappin in the car, one of us sits out with them. Our Ipad gets our WiFi with no issues and is pretty fast... the lovely NEW Ipad2 is iffy at best. what gives? anyone got any great advice?
Link the Lover of all Ipad
Amok
Southern California
I did experience some wifi difficulties at home. My wireless router kept resetting. I *think* that I solved the problem by updating the firmware on my router (D-Link DIR-655). So far so good.
Tim SPRACKLEN
Psdsoft
I have some issues with the WIFI on my Ipad 2 63gb/3g, it seems to have poor reception which varies wildly with no change in any other variable. Also on a speedtest, you can see lots of jagged graph and a drop off in sustained data transfer with time.
side by side with my macbook air, the air gets 56+mb/s on my N wireless network (Airport Extreme, feeding from a fast cable connection), the iPad peaks out between 2mb and 12mb/s on the same network, same distance same location etc.... I think the wireless drivers need some attention.
I tried the old trick of turning off the autobrightness and it improves a little but still slow.
Would appreciate others experience and ideas please.
Tim SPRACKLEN
One of our moderators suggested this...
"This has resolved many issues and worth a try.
__________________
Cheers
Col
col.bris, Brisbane Australia"
iRockSteady
Apple needs to address this issue and they need to do it NOW. Simply inexcusable. I even went to an apple and asked an employee about it and all they could say was they've never heard of such a thing, must be my network etc. WRONG. It's the damn iPad. Fix it apple. This is getting old really quick.
akintomide
Erith United Kingdom
The best thing to do is to return the iPad 2.
iRockSteady
Lucy you can edit your post by clicking on the blue downward arrow. No need to dbl post ;)
Link1369NY490
Link1369NY490
MA
Thanks so far, i will try all the above, EXCEPT the "return thrnI-Pad2" one. Thanks anyway! LOL.
Link
Link1369NY490
Link1369NY490
MA
Ya know... After a few more days of needing to reboot the WiFi to get it to sign on line... Even thugh it is says i "am on line" but i get NO reception i am agreeing with iRockSteady!!!! They need to fix this... The i pad 1 is better when it comes to WiFi connection. BUT so far that is my only complaint.
;0)
Colonial Heights,Va
;0)
My ipad1 is not immune. It too has started doing that. My wife never updated her same model as mine from the 4.2 it came with in the box and hers is trouble free. Mine started when I upgraded to 4.3.1 and then let the battery drain completely to calibrate the battery. My little yellow lights ( data is moving) on my router flash a few times when I first wake my iPad then just stop. The only thing that works is turn wifi off, then back on. I've forgotten the network, reset the device, done a total restore, etc. Nothing has worked.
Support Our Troops!
This post was Tapatalk approved
Sent from my iPad
iRockSteady
Support Our Troops!
Sent from my iPad
Idk what apple is up to but I haven't heard anything at all about them fixing this. Pretty annoying. I hate having multiple devices with strong signals while my iPad 2 is struggling... Not cool. Like I said earlier, maybe they ignored the strength of the wifi card in this to promote getting a 3G model... This is my ONLY complaint. I love everything else.
Link1369NY490
Link1369NY490
MA
I downloaded 4.3.2 yesterday, the WiFi is better, but not what it should be.
madcapjim
Midwest
Mine is no better or worse after the update, but this issue needs to be fixed. It's funny when my $149 kindle never drops it's signal but my $800 iPad does frequently. Actually it's not funny...
madhatter61
Minnesota
Apple just released iOS 4.3.2 that has a number of improvements and corrections. First, get the latest update installed. Then go thru some of the other steps recommended above as appropriate. My main point was to always get the latest update installed.
