Sound settings
ricmid
Y Ipad2 has stopped all sounds e.g. Keyboard clicks, sent email sounds (swoosh) etc. I have looked in settings and all sounds are properly set so don't know what to do next. Any ideas?
Hi and welcome to the Forum!
You haven't inadvertently turned on the mute button have you, it's the little switch just above the sound control.
Also look at the control which is found when you bring up your multi task bar. Do the 4 finger swipe up or double press the home button and you will see your multi task bar along the bottom, swipe right as far as you can go and you will see a volume control slide here. Let us know how you go.
I knew it would be something simple, it was the sound control icon on the task bar, thank you
