janetbryan said:
Fairly new iPad user.......there must be tricks to solving the frozen safari problem. Firstly, how do I reset everything in my first attempt to solve the problem?
Hi and welcome to the Forum!
There have been a few problems connected to Safari lately but try these steps:
Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
When your iPad begins to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
