Restore problems
Discussion in 'iPad Hacking' started by scottworland, Jan 22, 2012.
  1. scottworland
    scottworland
    Jan 22, 2012
    Yesterday i went to jailbreak my iPad 2 and everything went fine. Once i had the Absinthe icon i kept clicking it but it just kept taking me to the green poison website, i also tried the VPN switch thing as well but no luck.
    I done some digging around on the net and found a post that said it worked for them with a clean install of 5.0.1 and then restore your personal backup once the jailbreak has been installed.
    The trouble I'm having is that i now can't restore my iPad to factory settings, it pops up after it says 'verifying the install with apple' with an error code saying 'the iPad could not be restored. An unknown error occurred (21)'
    It then puts the iPad into recovery and i have to use Tinyumbrella to exit recovery mode.
    Can anyone help me with this? I just want it jailbroken, i should of stayed on 4.3 because it was jailbroken and running lovely :(
    Many thanks in advance
    Scott
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Are you sure you have the latest version of iTunes installed? You should avoid that error if it is fully up to date.
    Temporarily turn off anti-virus too if you have it.
  3. scottworland
    scottworland
    Jan 22, 2012
    I have the most up to date iTunes and I have removed sophos from my Mac. I still get the error 21
  4. RudyL90
    RudyL90
    Sep 13, 2010
    530
    9
    Your iPad is in DFU mode when you try to restore?
  5. scottworland
    scottworland
    Jan 22, 2012
    I think i put it in dfu mode, that's where there is the iTunes symbol and the lead on the screen?
  6. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
  7. scottworland
    scottworland
    Jan 22, 2012
    Ok, so i put the iPad into DFU mode and tried to restore and it come up with a new error this time 1600
    So i downloaded the stock apple firmware and tried again and held down alt before i clicked restore then selected the apple firmware and still the same error.
    Once i got the iPad back running again clicked on the absinthe icon and it still takes me to the green poison website where it says ABSINTHE is now setting things up, please stand-by...
    So no change, any ideas?
  8. RudyL90
    RudyL90
    Sep 13, 2010
    530
    9
    I am not 100% sure but I think error 1600 is caused by a setting in TinyUmbrella.
    Make sure "set hosts to Cydia" is unchecked.
    Hope that helps!
could not be restored an unknown error occurred 20 tinyumbrella
ipad could not be restored 1600
ipad could not be restored 1600 error
ipad restore 21
the ipad could not be restored 21
the ipad could not be restored an unknown error occurred (21)
the ipad could not be restored. an unknown error occurred (1600)
the ipad ipad could not be restored. an unknown error occurred (1600).
the ipad ipadcouldnot be restored an unknown error occured 1600
