Ipad 2 wifi jailbroken stuck in recovery, and wont restore,
Discussion in 'iPad Hacking' started by Kipperg1578, Feb 2, 2013.
  1. Kipperg1578
    Kipperg1578
    Feb 2, 2013
    7
    I have jailbroken my ipad its on ios 5.1 and i tried updating it and it put my ipad in recovery and now its stuck, and wont restore, i have tried using tinyumbrella to fix recovery by putting it in dfu mode, but it wont fix it. When i try to restore i get error 3194, any suggestions? I know this has something to do with hosts file
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    A quick search of the forum for "3194" would have revealed this - http://www.ipadforums.net/jailbreak...-how-resolve-itunes-unknown-error-3194-a.html
    If you follow the instructions, it will resolve the problem. Just to be clear, you cannot UPDATE a jailbroken iPad. You should only be using the iTunes "restore" option, and the only version of IOS which you should be trying to restore in this way is the current version, 6.1.
    If you really get into problems, follow this guide - http://www.ipadforums.net/jailbreak...lsafe-method-restore-current-version-ios.html
    Good Luck.
    #2 f4780y, Feb 2, 2013
  3. Kipperg1578
    Kipperg1578
    Feb 2, 2013
    7
    how to find hosts file?
    hello i jailbroke my ipad 2 and its stuck in recovery after trying to update, recovery wont fix on tinyumbrella and i cant restore, i have bo saved shsh, how can i get to my hosts file to fix it?
  4. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,405
    I have moved your post to this thread you created earlier and what you are asking ties into this previous post.
  5. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    The guide I pointed you to should help - http://www.ipadforums.net/jailbreak...-how-resolve-itunes-unknown-error-3194-a.html
    The location of the hosts file is mentioned at the end! PLEASE READ IT.
    hosts is typically a hidden system file, so you must normally unhide it on your OS, and use full administrator privileges to edit it, if you are going to do it manually.
    If you are still stuck, follow the SECOND tutorial I linked to.
  6. Kipperg1578
    Kipperg1578
    Feb 2, 2013
    7
    Ive tried this, thanks for the help, i have located my hosts file and it only had 1 apple reference and thats it, i removed it and its completely blank, i still get the error, i even tried moving the hosts file to another computer, Any suggestions?
  7. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    What versions iOS are you trying to restore? It can ONLY be the latest...
  8. Kipperg1578
    Kipperg1578
    Feb 2, 2013
    7
    Ios 6.0.1
  9. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    You cannot restore 6.0.1 EVER now. 6.1 is the only option.
  10. Kipperg1578
    Kipperg1578
    Feb 2, 2013
    7
    Ok ill try,
fix recovery ipad 2
how to fix recovery mode ipad 2 jailbore
ipad 2 recovery fix
ipad 2 recovery mode fix
ipad 2 stuck in recovery mode and wont restore
jailbroken ipad 2 stuck in recovery mode
jailbroken ipad stuck in recovery
jailbroken ipad wont restore
my ipad is stuck in recovery mode and wont restore
recovery fix ipad 2
