RealVNC Viewer problems
Discussion in 'iPad Apps' started by Skully, Nov 12, 2010.
  1. Skully
    Skully
    Nov 10, 2010
    First post from a long time lurker.
    Just got RealVNC viewer version 1.3.1 and I am having a real tough time getting the darn app to connect to a brand new windows box running win7 pro. This is a Company laptop that has VNC installed for remote trouble shooting.
    I have done all the port forwarding that is required on my router and still cannot get connected remotely using the Ipad.
    Does anyone have any suggestions?
  2. ocp
    ocp
    Nov 13, 2010
    7
    try logging into the pc from another pc use the pc viewer to make sure its not a server side issue.
  3. Bill Badger
    Bill Badger
    Nov 13, 2010
    Is this over 3G or wireless LAN? What are the security settings you have set up on the server? Did you submit a request to the tech support page at realvnc.com/support/iphone.html ?
  4. gentlefury
    gentlefury
    iPad Guru
    Mar 15, 2010
    2,615
    7
    I use RealVNC to log in to remote and local computers all the time...it works perfectly!
  5. Skully
    Skully
    Nov 10, 2010
    Gentlefury, thanks thats really helpful. plox
  6. Dannyboy85
    Dannyboy85
    Oct 12, 2010
    645
    I use iTeleport it's $24 in the app store. Yea, it seems like a lot but it works with both iPad and iPhone. Also uses gmail to connect so it's one of the easiest to setup for all those that are not so gadget inclined....
  7. Bill Badger
    Bill Badger
    Nov 13, 2010
    This sounds like competing companies posting on here! Skully - I upgraded to 1.3.2 although it didn't help with anything for me. But I have had help from the tech support people so try them before spending another $24 on another app, especially given I never had any real problems that weren't down to server config and thus nothing to do with the viewer. I refuse to believe that an app just can't work for some people, even though you hear about it a lot. If I had money for every time I saw "remote access app X doesn't work!!!" I'd be...well richer than I am now anyway! Do you have local admin on the PC you're trying to configure? I mean can you change the server settings?
  8. ocp
    ocp
    Nov 13, 2010
    7
    I have a number of apps that crash to the springboard everytime I start them. Even on multiple iphone 4s, so yes it does happen.
  9. Bill Badger
    Bill Badger
    Nov 13, 2010
    I meant that never work for some people but always work for others. But I put it really badly so you have a fair point.
error network connection lost vnc
ipad vnc network connection lost
vnc error network connection lost
vnc ipad network connection lost
vnc iphone error network connection lost
vnc viewer ipad network connection lost
vnc viewer issues
vnc viewer network connection lost
vnc viewer network connection lost on phone
