OS7 problem logging into imessage or facetime
jackieburk
I was able to fix my issues by doing a reset ((erase all content & settings ) and restoring to my backup. Big pain and very time consuming but it worked.
Milton-Freewater, OR
Unfortunately, sometimes that's what it takes. It's kind of like realizing that getting new furniture just isn't going to work. The room has to be emptied, painted, and have a new carpet fist. ;)
rsstacey
rsstacey
We'll did the reset and restore everything works but will not log into the app or music store. What a POS did Apple even beta this or was the release the beta test?
rsstacey
rsstacey
Well it sometimes takes twice but finally everything seems to work. Reset all again then App Store worked.
col.bris
Gold Coast , Queensland Australia
The apple servers are working overtime which is why authentication is taking time with millions upgrading to 7 plus 3 million phones sold every day it will take longer to activate some services. I just activated iradio today prior to that it was dead slow Talking about demand I am in Hong Kong and visited both Apple super stores here the line up was amazing what I found out the 5s is out selling the 5c and apple were activating hundreds of phones in store while customers waited.
I believe you will find accessing servers will ease over next week or so...so be patient. I would also try an alternative wifi connection from a free hot spot which may help. Cheers Colin
leehive
New here. I am having same problem with iPhone 5. My iPad seems to have done ok with io7 but cannot get iMessage/FaceTime to activate. Tells me to check my connection. Is the consensus to wait and let apple fix this mess or do full reset?
rsstacey
rsstacey
I had to reset the thing and start over via backup.
epacor
I have exactly the same problem and tried the fixes suggested with no luck.
Can't find much help on the net.
rsstacey
rsstacey
Your going to have reset everything and start frm scratch or wait to see if a future patch will fix it. I believe it's a bad download of the operating system.
