Ipad tv display out, help please.
Discussion in 'iPad Hacking' started by Ginopad, Nov 18, 2011.
  1. Ginopad
    Ginopad
    Nov 18, 2011
    I bought hdmi cable and the accessory for mirroring the iDevice to my Sony bravia tv. Unfortunately there is no sound, display of video is there, but the sound is coming from te ipad (ipad 1). Can someone help me? Please? Thanks guys! :)
  2. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,652
    35
    Which sound? Keyboard clicks or like music?
    Things like keyboard clicks, the sound it makes when you lock it, when you plug it in, and such wil come from the iPad speaker.
    But music, and sound for videos and such should come from the tv.
    Edit;
    Wow... I don't know how I didn't pick up on this before.
    Display out only mirrors video, no sound.
    To get mirroring and sound:
    1. Uninstall display out
    2. Download iFile
    3. Open iFile and navagte to system/library/coreservices/ SpringBoard.app
    4. Scroll down until you see K48AP.plist
    5. Tap on it and select "Property List Viewer"
    6. Tap on "capabilities"
    7. Down in the bottom right of iFile, tap the "+" button
    8. For the name, type "display-mirroring" (without quotes)
    9. Under that tap on type. Select "Boolean"
    10. Tap "create" in the top right of that window.
    11. Now, look in the list for "display-mirroring" and slide the switch to on.
    12. Reboot. If you are running a tethered jailbreak, reboot with redsnow, or snow breeze. Whichever you used to jailbreak.
    #2 graywolf, Nov 18, 2011
  3. Ginopad
    Ginopad
    Nov 18, 2011
    I already did what you said, just now. Same thing, sound's still coming from the ipad built-in speakers. Can you please help me further? Thanks :)
  4. Ginopad
    Ginopad
    Nov 18, 2011
    I don't really need the mirroring, i just want to play my videos with sound. Thanks :)
  5. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,652
    35
    If you did exactly what I said, mirroring should work, and videos should play with sound.
    Are you using the YouTube and videos app or another app off the app store?
  6. Ginopad
    Ginopad
    Nov 18, 2011
    Yup. What i did is uninstall the phone app for ipad (phoneit-ipad), everything works after uninstalling it. And after that I installed DisplayOut again, everthing's perfect, mirroring, sound and all apps (except garageband and some music apps with audio input). So, I think it's the phoneit-ipad. Displayout app is perfect for ipad 1 users, so they can maximize the potential, just like ipad 2 without a camera. Displayout also carries all the sound from the ipad. Thanks, Graywolf! :)
  7. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,652
    35
    I didn't know display out did sound too. :)
  8. starkiller
    starkiller
    Aug 28, 2011
    7
    Mine works perfectly fine. When i bought my HDMI cable I immediately purchased Display Out for my iPad 2 and its perfect. No issues with the sound at all.
  9. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,652
    35
    Well, it's all fixed now. :)
cydia display out audio
cydia display out sound
display out no sound
display out sound
displayout audio
displayout no sound
displayout ses sorunu
displayout sound
ifile display out
ipad 1 display out
