iPad 2 Netflix problem
Mbvirgo05
Atlanta
Okay on Netflix I can't see their faces ( blurry) because The video quality or something. Everything else is good. Can anyone tell how to fix this problem......please help.... :(
Kaykaykay
Your Internet connection is too slow. The only fix is to use a faster connection.
techkid420
Maple Grove, Minnesota
My. Kay is correct. Netflixs buffers the show but if it cant get far enough ahead it will never switch to HD. THe first minute of every show I watch on Netflix is always fuzzy while it buffers my HD. You need a better connection, nothing you can do on the iPad itself.
Sent from my Verizon 3G iPad 2 64GB using iPF
leelai
Brisbane, Australia
Hi and welcome to the Forum!
