Help with Word Document
JoeMC
Hello,
I just registered and I am not sure how to use this site.
I would like to use my iPad2 to open a MS WORD generated report which has a chart imbedded so I can insert photos I take with my iPad directly into the chart.
Pages wont allow me to insert photos into the chart in my Word document. I downloaded Kingsoft Office. KS Office allows me to insert the photos into my Word document and email it to myself. Only probem is some of my reports get very large with all the photos. I would like to find a way to drop my finished report directly into Dropbox or Google Drive. KS Office seems to have that as an option but I cant figure out how to get my document into Dropbox or Google Drive.
So my question is.. Does anyone know of a good app that would allow me to insert photos I take with my iPad directly into a chart in a Word Document that can be saved on my iPad and sent to Dropbox or Google Drive? Or help me figure out how to move my document from Kingsoft Office into Dropbox or Google Drive?
Thanks!
Joe
Hi Joe and welcome to the Forum!
I've taken the liberty of moving your post to its own thread, just so we don't interrupt that other ongoing thread you had posted in. I've also moved your post to the Help Forum where more members will see it.
Below you will find many links, one of which is a tutorial for our app.....I hope it helps you.
Good luck with your issue.
Tutorial for our App
http://www.ipadforums.net/new-membe...sistance/107524-ipad-forums-app-tutorial.html
Tutorial on creating posts on the Forum
Kingsoft Office probably supports the ability to Open In another app. Almost all apps do. You may have to poke around a bit to find it; often found under the Share options along with email.
If you download the DropBox or Google Drive apps, they should appear as options for Open In. Choose the appropriate app, and it will open with a dialog, usually to give you the options of changing the files name and/or folder to be saved in.
Good luck.
