Help on 3.2.1
Discussion in 'iPad Help' started by wolfslo1, Oct 31, 2010.
  1. wolfslo1
    wolfslo1
    Oct 19, 2010
    Help on 3.2.1
    Please some one help me out.
    I am running on a spirit jail break on 3.2.1. I went to do a restore and upgrade to 3.2.2 and re jailbreak with limera. When I go to do a restore on iTunes I get an error that says that it can not it can not access the updater files. So in long story short I can't update anything in version.
    Another question I have is since I am jail broken, if I update and reinstall cydia will I loose all the changes that I have done with cydia as in terms of licenses. Thanks for the input.........
  2. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    yes you will loose all your jb apps and changes.
    a restore, wipes out everything and loads your backup files back onto it.
  3. Pocobear
    Pocobear
    Oct 26, 2010
    608
    10
    No, you will not lose your licenses. If you use an app like "pkgbackup" from Cydia and use SBSchedualer from Cydia with it, you can backup all your apps and settings. Go into Pkgbackup settings for backup and check all the blocks. If you downloaded SBSchedualer you will be able to restore all of your settings also. So, when you restore, re-jailbreak and then re-download PkgBAckUp and install it, then do a restore within PkgBackup. This will re-download all your apps from Cydia and apply most all of your settings.
  4. wolfslo1
    wolfslo1
    Oct 19, 2010
    Thanks guys.
    Thanks guys. I backed up files and did a restore and rejailboak with jailbreak mw. Things are running way faster. I still can get to 3.2.2 because I get error 3002 every time I go to update.
