display help
dgrsjim
Florida
After using a while, iPad display jumps all over the place. It loads anything it feels like with no input from user. The only way I can stop it is to turn power off and repower.
J. A.
Apetlon, Austria
Hi, welcome to iPF!
I hope the following suggestions will help:
Reset your iPad: press Home & Power button at the same time until the Apple logo appears.
Remove apps from your multitask bar: double press your Home button to reveal the multitask bar, tap and hold an app until all start to wiggle, then remove apps there.
You could also try to restore your iPad: http://support.apple.com/kb/ht1766
Last option I'd know: Contact Apple Support or visit an Apple Store for an evaluation.
