Device sound on mute
Discussion in 'iPad 2 Forum' started by kehinde, Sep 14, 2012.
  1. kehinde
    kehinde
    Sep 14, 2012
    I use an iPad 2 and my music plays, you tube plays also but keyboard games and all other sounds are mute. I have tried virtually everything: restarted, reset, slide lock, double clicked home page and ll... But still to no avail.. Can some1 please help
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Don't worry. Lots of folks have the same issue. You just need to set up the mute correctly, and realise that mute does not necessarily mean what you think it might mean on the iPad ;)
    See this article for help - iPad: Understanding the side switch
  3. kehinde
    kehinde
    Sep 14, 2012
    I don't even have that mute bottom on th bottom left after I double click on home
  4. kehinde
    kehinde
    Sep 14, 2012
    I have the sound active now but the rotation remains locked... Please whats the way forward
  5. goofy8275
    goofy8275
    iPad Guru
    Aug 19, 2012
    2,598
    231
    Have you unlocked the side switch?
    And double tapped the home button and enabled audio?
  6. kehinde
    kehinde
    Sep 14, 2012
    Yes I did and it's working perfectly... The side switch was locked so I just pushed it on.
  7. goofy8275
    goofy8275
    iPad Guru
    Aug 19, 2012
    2,598
    231
    Now you're cooking on the front burner, cookie!
device mute ipad
mute
