Battery flat, then....................
I
islandman
Guest
scifan57
Regina,Canada
If you go to Settings>Battery, you'll be able to see if any apps running in the background were using an inordinate amount of battery power.
I
islandman
Guest
It says Home & Lock, 98% Safari 2% Time since last full charge 9hr 13 min
PS, I am updating to 9.3
I
islandman
Guest
Let us know if the update makes any difference.
Yes I will.
PS,
do you think a soft re-set, ie pressing Home & Power buttons for 10 secs will help?
do you think turning off "Background apps refresh" will help?
do you think turning off "locations services" will help?
all things at the back of my mind.
Jupiter7
South East England
A hard reset may help. Going through those Apps using Location Services and switching Location Services off for those that don't need it or not necessarily all the time might help. Shuttng down Apps running in the background won't help, but switching off Background Refresh will.
I
islandman
Guest
Agreed. Running the screen at full brightness will greatly decrease battery life.
30 hrs since charging up, not used, left in sleep mode, still shows 100% so either it was me being negligent, or the apps I removed were running it down or the fact we haven't skyped. Maybe I will never know.
