Silent/Screen rotation lock
sceadugenga
Adelaide
What does this do?
I see you can lock the rotation using the button revealed by an upward swipe.
So the little hole is?
OK, it's where the orientation lock used to be so i must have been looking at an old diagram.
Thanks.
Thanks.
Yes. The physical orientation lock switch went away, with the iPad Air if I remember correctly.
If you are looking at the iPad User Guide, make sure you have the most recent version (or the iOS version you're running). There should be a picture for every iPad model that will run that version. You can find it in the iBooks store (since the online guide only supports the newest iOS version).
