angel4avon
Itunes wont play purchased music on ipad 2.. Any fixes?
jolie11 said:Well, you could use iPod (it’s orange with an iPod-like symbol on it) to play the music. When you click it you get a list of all music on your iPad. As soon as you tip on one of them playback should start.
At the bottom you can chose how to display your library (by Artist, Album, Songs, &hellip
You'll need this guide: http://manuals.info.apple.com/en_US/ipad_2_user_guide.pdf
angel4avon said:I have that app loaded and some songs play. I am not seeing any pattern. some play, some dont. Seems like it worked ok before the os 6 update. Is there any way to uninstall the app and reinstall? I have looked everywhere.
When an app (or several) or misbehaving, I usually go through the following steps:
1. Force Close - open the multi-tasking bar (double tap the 'home buttom' or use multi-gesturing and swipe up); press & hold an app until all begin to 'jiggle'; find the offending app(s) and press the 'red circle w/ minus sign' - return to the home screen & try again.
2. Restart - press & hold the 'Sleep/Awake' (a.k.a. power) button until a red slider appears (may take a few seconds) - move the slider to turn off the iPad; then press & hold the same button until the Apple logo appears - wait for a restart.
3. Reset - press & hold the 'Power' and 'Home' buttons simultaneously until the Apple logo appears - this may take a longer time, so have patience; the iPad will 're-boot' - NOTE that none of these maneuvers will alter your apps, files, or settings.
dhewson777 said:The Music app itself is part of the iOS itself. I cannot be uninstalled or reinstalled separately. Try All of Giradman's tips first.
Are the "purchased" apps bought from the iTunes Store?
angel4avon said:It did not work. Yes, all music was purchased from iTunes Store. I just installed iTunes on my net book and it said I was authorized on 2 computers. I also have it on my desktop computer. Could it be that this ipad is not authorized for my account?
