Restart the iPad. Press *and hold* the Power button. After a couple of seconds a slider control will appear asking you to confirm that you really want to switch the iPad off (this is all you’ll be doing). Slide the control to accept. A rotating white ‘bezel’ will appear in the iPad screen as the iPad powers down (it takes a few seconds, just like it would if you were shutting down your PC). When the screen of the iPad has gone completely blank, press *and hold* the Power button for a couple of seconds until the white Apple logo appears and the iPad starts to power up. This takes several seconds, so be patient. During the power up the automatic screen orientation function is disabled, so don’t panic. A few seconds before the power up is complete, the iPad plays a little ‘jingle’ and then you’re back to the Home screen. Restart the iPad’s app and see if the problem persists. Apple (and Forum members) recommend that you power down your iPad at least once a week, just as you might regularly completely switch off your PC. The normal procedure of just briefly pressing the Power button of the iPad merely puts it to ‘sleep’. Most Forum members have found that this method I’ve mentioned here cure a whole bunch of unexplained problems and are an easy first step to resolving most anything that happens on the iPad.
