Wireless router connectivity issue
Discussion in 'iPad Help' started by ls224, Jun 29, 2011.
  1. ls224
    ls224
    Jun 29, 2011
    I have been experiencing issues obtaining consistent connectivity on the ipad 2, my laptop, and my wii connection. Changing setting on router to wpa2 provides great connectivity for the ipad2 but not my laptop and wii. Changing to wpa provides connectivity for my laptop and wii but not my ipad2. Any suggestions for consistent connectivity on all devices?
  2. GadgetGeek71
    GadgetGeek71
    Jun 28, 2010
    55
    What type of router do you have? Dual Freq.? Do you live in an apartment or condo? Have you made any big changes to the location of the router?
    Sorry for all of the questions but, one of these could be the culprit.
  3. ls224
    ls224
    Jun 29, 2011
    It's a d link router. I live in a house. No major changes to the location of the router. How can I check if it's dual frequency? I'm not sure about that one....
  4. GadgetGeek71
    GadgetGeek71
    Jun 28, 2010
    55
    Check the back of the router and, if it's dual, it should show both freq. (2.4 & 5 GHz). The dual band is a relatively new feature so, the age of the router will also determine if it's one or the other.
    Did all of your wireless devices start having issues at the same time? If so, you may look into buying a new router.
  5. Rog
    Rog
    May 27, 2011
    108
    On your router I would recommend not using the N ( use b/g) speed setting and changing the channel to a single number like 6.
    Wpa2 will work with a ps3.
    You may have to play around with the channels a bit but that should take care of it.
    Sent from my huge iPod touch via IPF.
  6. ls224
    ls224
    Jun 29, 2011
    The issues started when I got the ipad2. I couldn't maintain connectivity on the ipad2 under the wpa setting, but the laptop and wii were connecting to the internet just fine. Ipad would work for five minutes then stop, and I'd have to restart the iPad to get connected again. So it was suggested that I changed to wpa2 . Once I did that, the ipad2 had no connectivity issues but now, I couldn't connect on my laptop or wii. So I've been changing the setting back and forth from wpa to wpa2, depending on which device I'm using at that time. This is quite annoying as you can imagine!
  7. GadgetGeek71
    GadgetGeek71
    Jun 28, 2010
    55
    I think Rog nailed it...I completely forgot to mention changing the channel.
apple laptop ipad problems with wireless router
channel 6 for ipad2 wireless
d-link wireless router ipad issue
ipad 2 3 g wireless connectivity
ipad 2 internet connection issues
ipad 2 wireless connectivity
linksys 2.4 connection issues with ipad2
set wireless channel on ipad
wireless issues
wireless works on ipad not laptop
