Oh well. No idea why it's misbehaving.
You could try Settings > General > Reset > Reset All Settings. It's kind of drastic. It wont' erase any data, apps, or accounts, but many of your settings will go back to default; necessitating a careful examination of them all to make sure things go on doing what you expect.
Though, if you haven't tried a restart or reset yet, you should do those first.
The usual fixes:
Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. takes a bit longer than a restart.
Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
