Setting Up Email for Exchange 2003 Help
Discussion in 'iPad Help' started by tecboy, May 3, 2010.
  1. tecboy
    tecboy
    May 3, 2010
    18
    I am trying to set up my Ipad to sync my Exchange 2003 email. I can get to OWA via Safari by typing in url/username/password and it works fine. WHen i try to add the account via Microsoft Exchange on the Ipad, it fails with unable to verify account information. I did notice in my firewall log that the connection coming from the Ipad is using port 443 (https). Our Exchange server only uses port 80 (http) for OWA. How do i force the Exchange Active sync connection from the ipad to connect using port 80 only?
  2. tecboy
    tecboy
    May 3, 2010
    18
    nevermind...found the SSL button...had to scroll to bottom of screen
  3. kheldour
    kheldour
    Apr 6, 2010
    522
    lol.....good to know. Thank you!
  4. Esenjay
    Esenjay
    Mar 23, 2011
    Exchange and IPad
    I don't see a reply to the port number in the firewall question.
    The setup on the IPad for an Exchange account is fairly straight forward. However, I still only get the error "unable to verify account information". Do I need to open a port and/or is there an Exchange setting that needs to be changed? I know that in the past, IPhones wouldn't do Windows authentication so that had to be turned off for OWA to work. Is there something similar to that I need to do?
  5. phabas
    phabas
    Jun 2, 2011
    I am having same issue. Can anyone asist
connect ipad to exchange 2003
exchange 2003 and ipad
exchange 2003 ipad
exchange server 2003 ipad
ipad email unable to verify user name and password
ipad exchange 2003
ipad exchange 2003 unable to verify account
ipad exchange connection unable to very account information
unable to commect exchangenon ipas
unable to verify email account information ipad
