Seagate GoFlex Satellite/AVPlayerHD Question
Discussion in 'iPad General Discussions' started by RickD_99, Mar 21, 2012.
  1. RickD_99
    RickD_99
    Jun 1, 2010
    5
    Had a question for you Seagate GoFlex Satellite users: if you wirelessly connect your iPad to the GFS can the native apps on the iPad "see" the GFS files on the external drive? For example I have the iPad AVPlayerHD app which I use to view video files in mkv format. Assuming I have opened the GFS app and connected to the GFS drive will AVPlayerHD be able to see the files on the drive and allow me to play them? Normally when using AVPlayer HD i have to transfer the mkv files directly from my PC to the iPad.
  2. nucloid
    nucloid
    Apr 1, 2012
    GO Flex
    I can't get this app to work with go flex satellite at ALL!! HELP, please -- I like this app, but i have all my movies on the go flex
  3. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,415
    435
    The app has to be designed to work with the goflex. If their dont advertise that it will, it very much likely won't. The iPad is not a PC.
  4. dhewson777
    dhewson777
    iPad Ninja
    Feb 23, 2012
    1,589
    163
    My understanding is that you need the GoFlex Media app to access the files. How that interfaces with other apps I am not sure.
  5. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,415
    435
    I returned mine but when I had it I recalled it only worked with the built in player, though I'm not sure if changes have been made or not. But I know that AV Player HD wants to play files stored in its own space and it won't see any other movie files (I wish it would) since apps on ios live in a walled off garden (pros and cons to this). I do wish they would add support for external movie files because I am considering buy either another goflex of a hyperdrive.
    OP: you might consider contacting the developer to ask. If you do, kindly report back what you learn as other may have similar interest.
  6. drb_52
    drb_52
    May 19, 2011
    184
    5
    My goflex wifi works with buzz player. It's not free, but it works with many video file formats.
av player hd seagate satellite
avplayer hd goflex
avplayerhd
avplayerhd goflex satellite
avplayerhd seagate
avplayerhd seagate satellite
extra storage for ipad avplayerhd
how to connect avplayer hd to wireless hard drive
oplayer hd sattelite seagate
tranfering movie from goflex to avplayer
