Public Wifi Issues
Discussion in 'iPad Help' started by ruready, Jun 2, 2011.
  1. ruready
    ruready
    May 14, 2011
    17
    I have a 32 g WIFI IPAD 2, I am able to connect via Wifi at home just fine. I am even able to connect on someone else's wifi in my building even though it shows as two bars as signal it seems to be just fine as well. But if I am in public like a park or public space where they have wifi I have so much trouble connecting even when it shows it has 3 bars? And when it does connect the connection can be really slow, am I doing something wrong is this a known issue, do I have to be really close to the access point or is there a lag because so many people are using the connection at once?
  2. sjleworthy
    sjleworthy
    iPad Ninja
    Jan 14, 2011
    2,051
    108
    Poor public wifi issues isn't your fault, it's theirs.
  3. theapcoach
    theapcoach
    May 31, 2011
    9
    While sjleworthy makes a fair point. There are other factors which could obstruct the strength of the signal.
    For example if the wifi is near civic buildings in a city centre, the type of stone they were constructed with can block or interfere with or obstruct the signal.
    So where ever you chose to sit down and use public wifi the strength of the signal will always be affected by whatever material it encounters in its path to where you are seated.
    The technology was only developed for short distances so even in a public place you will have to be located fairly near the source of the signal to get a good reception.
  4. chevyguy
    chevyguy
    Mar 16, 2011
    174
    Also public WiFi gets hammered with bandwidth, if you're in a place that has a ton of people sharing the WiFi, it's gonna slow down. Probably not your iPad, but the amount of people sharing. :)
  5. Rlarson_mn
    Rlarson_mn
    Jun 22, 2010
    112
    Same thing can happen in a coffee shop setting if lot of other customers are there utilizing the free wifi. It's all about sharing band width in the wifi world.
connecting to public wifi with ipad
how to connect ipad mini to public wifi securely
how to secure ipad mini on public wifi
ipad 2 not connecting to public wifi
ipad and public wifi
ipad not connecting to public wifi
ipad wifi security in public places
ipad will not connect to public wifi
public hotspots for wifi i pad
slow to connect to wifi hot spot ipad
