Problems with office2 HD
Discussion in 'iPad General Discussions' started by princesZee, Jan 8, 2012.
  1. princesZee
    princesZee
    Jan 8, 2012
    Hi im experiencing problems with office2 HD. It gives me blank pages on Files. Cannot edit my work as it seems the pages have disappeared. It also muddles up some of my paragraphs. The spacing aswell, there are large gaps in between sentences which I have to fix all the time. Please assist
  2. sjleworthy
    sjleworthy
    iPad Ninja
    Jan 14, 2011
    2,051
    108
    sounds like either.....
    * your copy is dodgy or currupt. erase it and re-download it for free
    * you're trying to import and use material from too many sources - most ipad office apps prefer 'in-house' production if possible.
    * you're completely not using it properly with regard to reading instructions is concerned.
    i use Office2HD on a daily bases and love it. have zero issues with it. I use files between it and ms office on my pc every day. Your problems might better be resolved by the dev team, who are good to talk to :)
  3. princesZee
    princesZee
    Jan 8, 2012
    Hi
    Do I need to back my work before deleting it? I mostly use it to type my scripts is there maybe another program I can use aswell? I had no problems until the upgrade.
  4. sjleworthy
    sjleworthy
    iPad Ninja
    Jan 14, 2011
    2,051
    108
    Yes, I'd certainly wifi out your data before erasing it.
    But for script writing, why not try an app like Manuscript or something more applicable?
how to close files properly in office2 hd
office 2 hd issues
office 2 hd problem
office 2 hd problems
office 2 hd troubleshooting
office2 forum
office2 hd
office2 hd help
office2 hd ipad troubleshooting
problems with office 2 hd
