Problem with sound
Kaff
Hi everyone I have a question would like to know how to fix the sound on my NEW iPad 2. I haven't had it even 3 months and already the sound has gone out. Please let me know what I can do. I hit the reset/restart button 3 times & refreshed it all out of ideas. PLEASE SOMEONE WITH TECHO SKILLS HELP. THANK YOU
SaberOne
Arizona
Well, I haven't decided if I'm a fan or not but I sure like it thus far! :D Anyway, welcome to the money pit hobby of mobile madness.
f4780y
Troon, Scotland
Have you lost all sound, or just some sounds?
Double check you did not slide the mute switch on the side of the iPad.
Kaff
Kaff
Thanks SaberOne didn't feel like much of a fan a few hours ago either. I had a sound issue with my BRAND NEW iPad 2. I thought I haven't had this thing even 3 months and all ready it's giving me the blues. However, I found a solution to my problem while researching a solution. Anyone out there with a sound problem with your Apps or the keyboard clicking sound this is how you fix it. Hit your home key at the bottom of your iPad TWICE. After you do that you should see a bar/dock appear for easy access to other apps. Scroll to the left and where your iPod settings are look for the sound picture hit it to make sure it is not on mute (like mine was) :) THERE YOU HAVE IT. I hope this helps anyone with this problem. Enjoy your iPads guys
Kaff
Kaff
Thanks f4780y for the assistance I just found the solution  Wondering though the iPad 2 doesn't have a mute switch on the side does it only the sound button for volume adjustments right.
Gabriel1
Cranbrook, Kent, UK
That button can either lock rotation of the screen or mute the sound depending on how it is set in settings Settings >> General >> Set Side Switch To
f4780y
Troon, Scotland
You can change what the switch does between rotation lock and mute in the Settings app. Many folk change this then forget and slide the switch.... If you change the setting, the soft key you pressed to mute becomes the rotation lock key...
Kaff
Kaff
Didn't know you could do that thanks for the info. 
Kaff
Kaff
Thanks Gabriel for the heads up learning new things everyday with this. ,"k
Kl
Ki
SaberOne
Arizona
It's been my experience with anything tech' that most issues are easily solved in settings. Especially if something goes weird following an update or resource install.
luralin
I first heard new iPad 2 has this problem, so you have checked all the button problem? hope you can get a well iPad at last.
John Daerson
iPad is the wonderful device!! i love all the apps of iPad 2.. Well all the tech issues in iPad can be solvd easily thru the manual and Google!
