Problem with ipad 2 3G
Discussion in 'iPad Help' started by manlyloveyou, Jul 13, 2011.
  1. manlyloveyou
    manlyloveyou
    Jul 12, 2011
    6
    I have a trouble about 3G. It only appear Searching.... After that is No Service. I'm not amater when using ipad. So i can't solve this problem. Who could help me?
  2. KaiHD
    KaiHD
    May 30, 2011
    562
    Is the SIM inserted properly? Have you correctly set the APN in Settings? Is your SIM card activated by your service provider? Is the account with your provider active?
    - Sent from my Highly-Personalized jailbroken iPad 2! :D
  3. manlyloveyou
    manlyloveyou
    Jul 12, 2011
    6
    Everything is corrected and check but the problem does'nt solve. I saw sim application and cellular data number and carrier but it still No Service.
  4. KaiHD
    KaiHD
    May 30, 2011
    562
    Is the SIM card taken from a mobile phone? If you can see the number, it probably is. SIM cards for phones do not work on iPad. They have voice telephony, which is not supported by iPad. You require a data SIM card that handles only data (and in some cases SMS).
  5. manlyloveyou
    manlyloveyou
    Jul 12, 2011
    6
    I did everything as you said but it still. Somtime i turn on cellular i see Viettel 3G and it works only 5' althought i checked my account and full money.
  6. KaiHD
    KaiHD
    May 30, 2011
    562
    What do you mean "5"? Sometimes your account data may not be activated. Other than that, try restoring your iPad in iTunes. After the restore, iTunes will ask if you want to download carrier settings for your iPad. Click 'Yes', and your Internet should work. If not, try to ask your provider about your account, and how to use your account with your iPad.
    Worse come to worst, take your iPad to your provider with the SIM card (like a carrier outlet). For example, I'll take my iPad with my DiGi sim card to a DiGi store. They usually will fix it for you. If not, it might be that your carrier does not support data on iPad. Keep in mind that I can't help you anymore after this, because I do not live in your country and as such, do not know how things work.
    The best thing after this is to find a user here that is from your country. Also, check the 'iPad Carriers' section in this forum. They usually have something for cases like this. Also, try the international forums- Someone from your country might be able to help you.
  7. manlyloveyou
    manlyloveyou
    Jul 12, 2011
    6
    Thank you so much. And i will find someone with same my trouble.
  8. DefBref
    DefBref
    Apr 14, 2011
    978
    53
    Are you perhaps just in a place where you can't get a 3g signal, its not ubiquitous you know. It depends on coverage, for instance I can't get a 3g signal at my work place but can at home.
  9. Winam
    Winam
    Jul 4, 2011
    88
    I would have assumedthat as well. I have the same thing here.
    Sent from my iPad or IPhone using Tapatalk
  10. KaiHD
    KaiHD
    May 30, 2011
    562
    That did not occur to me... Wow, really says something, doesn't it?
cartela rds ipad no service
digi simcard problems no network coverage
ipad 2 3g data problem
ipad 2 3g problem
ipad 2 gsm no service
ipad 2 shows no sim malaysia
ipad 2 sim card no service help
ipad trouble cannot detetct sim
ipad with 3g sim but it does not shows the signal
problem with ipad 2 3g reception
