No sound
ronguida
Just downloaded the new HBO app using Verizon, and no sound. Is there a fix?
Tim SPRACKLEN
profabe
No sounds on iPad for HBO GO
I have same problem. The headphone jack does work for audio.
Makes no sense. One of the forums says to lock the rotation on the settings but that doesn't seem to work.
Tim SPRACKLEN
I think the Forum comment was to be sure whether you had Mute active. On iOS 4.3 and up there was an option to re-assign the Mute switch (by the volume control) to the orientation lock, at which point the mute functionality would be transferred to a control in the multi-task bar, which you can get to by double-tapping the Home button and flicking the multi-task bar to the right, where you will see the Mute control.
So check to see if Mute is activated.
