new to forum....bluetooth apeaker problem help
cb1
hi all...i am new to the forum...i have an ipad 1 and a logitech mini boombox. they synched perfectly at first. now my music skips when playing.....any advice?
Hi and welcome to the Forum!
This may be the app misbehaving rather than Bluetooth. When an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly. Let us know how you go.
thanks...tried that, but didnt help. my friends ipad music skipped on my mini boombox. but then it worked fine on his mini boombox at his house. mthat tells me its something with my boombox device or in my house
It would appear that it may be a problem with your boombox. Do you stream your music with iTunes match at all as this would require a good Internet connection? Can you connect your boombox to another device, iPhone perhaps?
