Thanks for helping. I have the iPhone 4 iOS 7 and no idea what iPad iOS 7 also. I checked all my settings and all on both devices are turned on.
Hi again - iOS 7 is the same OS on your iPhone - I'm assuming that your iPad has been upgraded to that version (if you're not sure, then on the iPad go to Settings > General > About - your iOS version is halfway down the list). If you are on an older iOS (e.g. 6.x) version on your iPad, then you might first consider upgrading, and then determine if your images will sync as desired. Also, are you using Photo Stream for your syncing? I'll stop there and let you respond. Dave![]()
