Need help with keynote, importing media!!
nate1224hoops
Okay, I've done my research. Here is what I know: I have keynote for ipad2, I use pc at home, and I've read everything I can find.
Here's what's happening. I teach school so I use united streaming videos in class. I want to place those in my keynote presentations. I have converted the files. The files sync to movies and as you know keynote only pulls from photos. So I read somewhere to create a folder with my other pics on pc and put bids in it. I did this. Then open iTunes and go to photos. Then click sync, choose folders,....choose folder I just put vids in and select add videos. I do all of this and when iTunes gets to step 5 of 5 of sync it shutsdown. It says it isn't responding and must close.
Can anyone help???
Milton-Freewater, OR
It sounds like you are doing everything right. Try removing all but one movie from the folder, one that you know will play on the iPad, and give it another try.
That is all I can think of at the moment.
