iPad sound cutting out/ intermittent
Discussion in 'iPad 1 Forum' started by Legbreaking, Dec 2, 2011.
  1. Legbreaking
    Legbreaking
    Dec 2, 2011
    Hi guys
    I'm having a few problems with the sound on my iPad. I'm running the latest os.
    The sound in all apps and other sound eg keyboard clicks stops working intermittently, and the volume slider when I double click the home screen disappears. The sound sometimes comes back for a few seconds then goes again randomly. NB. Sound works fine with headphones
    I've done a lot of reading in other post, and have tried the following:
    1. Messed about with the mute switch/screen lock switch on side of iPad as well as in the settings menu
    2. Complete system reset via settings
    3. Reset holding home and lock
    Nothing has worked.
    Anyone experienced this? Anyone got a solution?
    Many thanks in advance, it's driving me nuts!
  2. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,828
    1,306
    Hi and welcome to the Forum!
    Regarding your issue have you closed all your apps completely in the multi task bar? Try this :
    Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. If not do a restart
    Another thought also, when you are playing using your headphones it is a good idea to stop the app first before taking your headphones out. Let us know if this makes a difference
  3. Legbreaking
    Legbreaking
    Dec 2, 2011
    Thank you for the help, I've tried what you've suggested but the sound still continues to cut out.
    Anyone else experienced this?
  4. a3.trion
    a3.trion
    Feb 15, 2012
    My ipad is having the same problem. Same as described. I even tried restoring but sound still intermittent.
  5. mosweiss
    mosweiss
    Sep 8, 2011
    8
    Same here. I think it's something to do with Bluetooth speaker interaction. Who knows? I close the app and make sure it's not running and the sound goes back to normal.
  6. Snowy3uk2
    Snowy3uk2
    May 20, 2012
    I have had the same problem with my ipad2. I tried a hard reset and on the advice of Apple i tried a full factory restore without then reinstalling any media or apps. When having done this I still found intermittent sound problems Apple agreed to replace my ipad as it was within its warranty period.
    I strongly suspect that this is a hardware issue and to do with the headphone port. I was able to get sound back by removing and
    replacing the headphones although the sound would fail again after a while. This may be as simple as having dust/dirt in the socket
    so if your ipad is not under warranty i would suggest trying a blast of compressed air in the socket.
  7. Lytrela
    Lytrela
    Jan 28, 2013
    Same problem here. I changed all my settings then resorted to a complete system reset but the problem recurred after a few days. I just discovered that closing the cover and plugging then unplugging my headphones fixes it (thanks for the input Snowy3uk2). This may be only temporary as well, but I'll take it over a reset. I'm far from any Genius bar.
  8. peter122
    peter122
    Jan 9, 2013
    6
    Trie and restart it that might work or take it in to the shop
  9. drakedane
    drakedane
    May 6, 2015
    I am having a similar issue with audio suddenly muting. although i am not sure about the cause (started happening, unexpectedly, after having ipad for a long time), the temp fix i use is to simply hit the up or down volume on the external BT keyboard; and the sound immediately begins to play again.
    Maybe someone else can try this, to see if it works for them. never use my ipad without external keyboard, but maybe just try hitting volume buttons on ipad, to see if that fixes it. seems like this mostly happens when watching vids on youtube and sometimes my slingplayer. but, when i play the alex jones audio stream, i don't think i have ever experienced this issue.
    I should note that, once the problem starts, the "temp fix" is VERY temporary, and sometimes the problem recurs every few seconds or minutes, requiring me to keep hitting my volume keys, to keep the sound on and working.
    Very frustrating!
  10. tracyleigh33
    tracyleigh33
    Oct 11, 2015
    I am having the same issue with my iPad mini. It does seem like it has to do with the headphone jack. It seemed that the sound worked with the headphones or earbuds for awhile, but the sound cuts off just the same. Works again after a restart, but not for long. No fun!
intermittent sound on ipad
ipad intermittent sound
ipad intermittently loses sound
ipad sound cuts out
ipad sound cutting out
ipad sound goes in and out
ipad sound keeps cutting out
sound cuts out on ipad
sound keeps cutting out on ipad
sound on ipad keeps cutting out
