Search for solution to intermittent sound problem.
Discussion in 'New Member Introductions - Site Assistance' started by mterry, Mar 14, 2013.
  1. mterry
    mterry
    Mar 14, 2013
    I have a sound problem with my iPad. The sound comes and goes, in fact it is doing it as I type this. I hear the keyboard clicks, then they suddenly stop. When I look at the volume slider in the open app tray, the entire slider disappears with the sound. I can turn the mute on and off, but the sound doesn't come back when on.
    Does anyone have a solution?
  2. The OB
    The OB
    Staff Member
    Aug 10, 2012
    4,616
    1,642
    Welcome to the forum mterry!
    If you have not already done this, do what Apple recommend should be done periodically to clean up RAM and cache and make your iPad run more sweetly. Do this:
    Simultaneously hold down the On/Off and Home buttons until the screen blacks out. Keep holding both until the white Apple logo appears and then let both go. Then wait until your wallpaper appears. Then start your iPad.
    Regards, Andrew
  3. mterry
    mterry
    Mar 14, 2013
    Thank you for the response. Yes, that was one of the first things I tried, but the problem continues.
apple ipad -no sound problem
intermittent ipad audio problem
intermittent sound on ipad
ipad intermittent sound
ipad sound intermittent
ipad sound is intermittent
ipad sound problem
ipad volume intermittent
sound comes and goes on ipad
sound on ipad comes and goes
