kiwibrian
Subject as per Title.
Thanks skimonkey - I was unable to change/edit the title of the other query. I have a Wireless Plus device and have many EPUB ebooks, all without DRM. I have transferred them onto the WP device from my PC using the special cable/plug device which came with the WP. I have not been able to find a tutorial describing how to access them in the iPad from the Wireless Plus device. I have seen comments that file-types that are not natively supported by iPad can use the apps which do support EPUB format to access/display EPUBs but have not seen a description of how to do that. Documents 5 by Readlle are my preferred apps that I would like to use to display them. Hope that clarifies my query. TIA.
Hi Giradman - thanks for your reply. My device is Seagate Wireless Plus which I gather is their latest/new 1Terabyte model. Like you I use Dropbox and know that the process works as I have used it in the past to install EPUBs into Documents 5 by Readdle and also iBooks in the iPad using the PC, however I would like to be able to use SWP just as I can/do with PDFs and DOCX files. I have seen comments that "file-types that are not natively supported by iPad can use the apps ....." which do support EPUB format to access/display EPUBs but have not seen a description of how to do that.
Yes I do have the Seagate Media App installed. I have just had another try, and do not see an Open In option anywhere. I have given up until someone who has a Seagate Wireless Plus and can upload EPUB files successfully pops up. Thanks to you all for trying.
