Apps That Drain Your Battery Faster
Discussion in 'iPad General Discussions' started by Sonny Burnett, Sep 28, 2010.
  1. Sonny Burnett
    Sonny Burnett
    Mar 7, 2010
    752
    I have noticed that We Rule seems to drain my battery faster. Anyone else have an app that they would like to add to the list for battery charge over consumption?
  2. j0yful
    j0yful
    iPad Addict
    Jun 11, 2010
    1,174
    22
    farmville app
  3. iPadCharlie
    iPadCharlie
    iPad Super Guru
    Jun 19, 2010
    4,231
    7
    Well maybe they don't really drain the battery faster, its just that you get so caught up in playing the game that you lose track of how long you have been on your iPad and the hours just tick away before you know it!
  4. Protegeone
    Protegeone
    Sep 3, 2010
    46
    It's Solitaire City Lite for me and not because I get carried away playing it
    either.
    This app just simply drains battery superfast for some reason.
  5. DewWorm
    DewWorm
    Sep 10, 2010
    15
    As one should expect I suppose, the GPS HD and Drive HD are best used with the car charger or inverter plugged in. Any app that uses heavy data transfers will cause heavy battery drainage, but if you are using your iPad as a computer or GPS what else could you expect? No matter, I love my iPad!:D
  6. bieber fever
    bieber fever
    Sep 26, 2010
    18
    You can lower the brightness, get rid of the notifications, etc.
    It'll help out some.
  7. ArthurIhde
    ArthurIhde
    Sep 23, 2010
    118
    yes,i have the same problem
  8. Sonny Burnett
    Sonny Burnett
    Mar 7, 2010
    752
    So what would drain the battery faster? Using one of the above mentioned apps or playing videos?
  9. NumbLock
    NumbLock
    iPad Ninja
    May 2, 2010
    2,008
    32
    Any gaming - especially those with 3d effects and lots of animation. Seems normal to me: lots of processing power being used me and lots more battery being used.
  10. iPadCharlie
    iPadCharlie
    iPad Super Guru
    Jun 19, 2010
    4,231
    7
    Of course the biggest battery hog is the screen, but I don't think the processor uses significantly more power when playing a game as opposed to watching a video. OTOH, the 3G section and the WiFi section can in fact suck more juice out of the battery.
app to drain battery on ipad
apps that drain ipad battery
do unopened apps drain battery
do you use a lot of battery playing games on ipad
how to drain ipad battery
how to drain your ipad battery
how to drain your ipad battery fast
ipad app to drain battery
ipad apps that drain battery
ipad battery draining apps
