3G drops to E and does not return to 3G
Discussion in 'New Member Introductions - Site Assistance' started by rd_bhatnagar, Nov 29, 2010.
  1. rd_bhatnagar
    rd_bhatnagar
    Nov 29, 2010
    I am struggling to get the actual feel of the 3G connection on the iPad. The 3G on the status bar changes to E very frequently and does not return to 3G, though the service provider has demonstrated that his signal does not fluctuate.
    I have not upgraded to 4.2.1 yet.
  2. deckyon
    deckyon
    Sep 15, 2010
    612
    Service between towers will always fluctuate. The signal from the servers may be constant, but any over the air waves will flux.
    Things to pay attention to - time of day, weather, traffic, your distance from the towers. All of these things can cause degradation in the signal between your device and the towers as well as between the towers themselves.
    For me, while it stays 3G, during lunch I notice a decrease in speed while on my iPad.
  3. Omanlive
    Omanlive
    Nov 21, 2010
    9
    I hope we can force 3G connectivity in iPad
  4. JGibson
    JGibson
    Nov 29, 2010
    An almost similar problem with my 3G it was low signal or no signal at times. Even with a tower 1/2 mile away. Took it to a apple store, they first told me to change the sim card and then when that didn't work. They did a diagnostic and found my iPad was at fault and they gave me a new one. Before taking it to a apple store make sure you update it and I would get a new sim card, and get a receipt for the card. I compared with my friend on signal strength standing in the same spot. Otherwise I just thought it was poor AT&T signal. I hope this helps.
  5. rd_bhatnagar
    rd_bhatnagar
    Nov 29, 2010
    Well this could be rare. In India there is no apple support who can do the diagnosis. Can a hard reset help in this case.
    The thing was working quite well a few days ago.
e instead of 3g
e status on an ipad
how to change e to 3g on ipad
ipad 3g e
ipad internet service 3g but e
ipad signal always e
my phone indicates e instead of 3g
switch from e to 3g ipad2
why am i on e instead of 3g?
why do i keep getting an e instead of 3g
